UE 3 not sending using PHP mail
Thread began 6/22/2011 4:29 pm by lee341019 | Last modified 6/24/2011 5:14 pm by Jason Byrnes | 1562 views | 12 replies |
lee341019
I cannot get my site to send using UE3. It used to work. My hosting company say nothing has changed. I am not sure where to start looking!! Help!
This is using User Registration Solution Pack.
I have packaged the files if someone could help??
Who is your hosting company?
What have you entered for the SMTP server in the wa_globals.php file?
are the $WAGLOBAL_Verification_Email_FROM, $WAGLOBAL_Registration_Email_FROM and $WAGLOBAL_Password_Email_FROM all set to valid email addresses from your domain?
in the WA_Universal_Email/mail_PHP.php file, try changing:
$mailObj = mail($mailTo,$mailSubject,$mailContent,$mailHeader);
$mailObj = mail($mailTo,$mailSubject,$mailContent,$mailHeader, "-f".$mailFrom);
if all of the setting s are verified as correct, and it is still not working, then there is an issue with the smtp server refusing to relay the email for some reason, you will need to contact the host to have them look into the smtp server error logs to see why the relay is failing.
lee341019
All values appear valid. Below is reference from Globals file.
$WAGLOBAL_Email_Server = "localhost" ;
that may or may not work depending on the host.
try leaving the smtp server blank, or check with the host what the correct address to use for the smtp server should be.
lee341019
I have tried 'localhost', the ip address (I have a linux VDS) and leaving blank but none work.
I have asked my hosting company to look into it (CWCS in the UK).
Any other ideas?
if all of the settings are verified as correct, and it is still not working, then there is an issue with the smtp server refusing to relay the email for some reason, you will need to contact the host to have them look into the smtp server error logs to see why the relay is failing.
lee341019
thanks anyway for your help.
lee341019
I now have the mail working, but have another problem.
When a use registers, I get sent an email with their details, which is fine, but the email which the new user receives (to verify their email address) contains no body, just a subject line, so they cannot verify the account. Help!
users_Registration.php
send a copy of the users_Registration.php file in a zip archive so i can look at the code.
lee341019
attached. Thanks
users_Registration.zip
