Thinking about purchasing validator toolkit
Thread begun 6/22/2011 11:15 am by watercolor346374 | Last modified 6/23/2011 2:00 pm by Ray Borduin | 2937 views | 3 replies |
watercolor346374
I am thinking about purchasing the validation tooltips for spry. I was wondering if it would work on the attached script. The form fields are set up so that there are labels inside the inputs. Will this make the program think that the form is validated? or will you program be able to validate this form.
Thank you,
K
Your html is bad.... a lot of your inputs have: Name"
in the code, which will cause DW to not recognize them... by removing that you could then apply Spry validation with DW and then use our Validation Tooltips to style the resulting validation messages.
At the end of the day it should be possible to get this to work.
watercolor346374
validation tooltips
Thank you. So I would have to first use the DW spry validation then use your program.
Yes. It will augment the spry code which has to be applied first.
