Many to Many Delete
Thread began 6/21/2011 10:04 am by codamedia | Last modified 6/21/2011 11:18 am by Jason Byrnes | 1175 views | 3 replies |
codamedia
Many to Many Delete
I am using the DataAssist "Manage Relational Table" to create a Many to Many relationship in my database. This is working fine.
If the user deletes a record from the main table, I like to automatically clean the "many to many" table by removing all associated records.
Is there an option for this that I am missing or do I have to manually write this code?
you just need a second delete record server behavior to delete the records from the relational table.
it will use the same variable as the initial delete for passing the ID.
codamedia
Thanks Jason - I was over thinking this one :)
no worries, most people do over think deleting records.
