current state or 'you are here' problem
Thread began 6/21/2011 9:50 am by edrosenthal350859 | Last modified 6/24/2011 10:31 am by Jason Byrnes | 1316 views | 5 replies |
edrosenthal350859
i'd like to have the current page - you are here page- menu white and all the other
main menu items in grey. right now i have them all in grey but the current page is not
white.
i am testing on a server where i am using an ip address so that could be the problem -
because in another thread the issue sort of came up and the resolution had to do with the page name i believe.
could you suggest that the issue is elsewhere, or will it clean itself up when we switch to the regular domain name and page names are the same as in the menu code?
thanks in advance
~sequoia9/
e
change this line:
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 3, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 3, orientation: 1}); }, true); }</script>
edrosenthal350859
see result...
now the colors are all white across the board, and the background colors have also been changed. i don't see a current state at all, as before.
actually i have gone through some experimentation with the menu, and like it, but i guess i don't have enough css to understand the implementation and changing, but i am a persistent tweaker, when given enough time i guess a monkey could write some shakespeare...
still need help though..
e
In the CSS Menu Writer Wizard, Click the Edit Design option, on the Ont he design tab, select the Currant tab to set highlighting options.
for more details, see the menu writer help documentation at:
index.htm
go to Modifying the Design -> Design -> Highlighting Current Page
edrosenthal350859
re document
one addition thing shows up and i can't see where it's coming from:
on the page sequoiapacificmortgage-team.php
this is the one page of the menu that has level-1 rules, and the top menu level shows a border like about 2 pixels
at the bottom of it. when you use the home or the contact or the programs buttons the highlighted menu 'button'
does not have a border like bottom, but this page does. i've looked at all the rules and don't see where this is coming from.
any suggestions welcome!
thanks in advance.
eddie
you asked this in another thread as well:
showthread.php?t=21351
see my reply there.
