Change: image sizes, thumbs, and background for "Ribbon + Fullsize + Lightbox"
I really need to change the size of the images and the template for:
I have so far managed to change the size of the images to 400px x 300px using this thread:
showthread.php?t=8844
However, when it comes to changing everything else I have come across problems…
Using this PDF:
powergallery_custom_gallery_ht.pdf
I have managed to change the number of thumbnails from 10x to 5x, however from there it gets problematic as it only refers to the "common.css" file for:
"Ribbon + Lightbox" and "Grid + Lightbox"
as opposed to:
""Ribbon + Fullsize + Lightbox"
Which appears to be different!..
Here is a link to what I have done so far:
holiday-home-to-rent-in-looe-2.php
Can someone please tell me how to now adjust the sizes of the outline grey box and the grey ribbon along the bottom so that everything fits within the boarders of the white background??..
Also:
As you can see in the link above I am also getting the following error message:
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/islandvi/public_html/gallery/galleries/global.php on line 19
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/islandvi/public_html/gallery/galleries/global.php on line 22
Is this just because the frame is too big for the page or is there another issue???..
Just in case it is needed Here is the code that it refers to:
14: chdir($globaldir );
15: mysql_select_db($database_powergallery, $powergallery);
16:
17: $GLOBALS['wa_settings'] = array();
18: $result = mysql_query('SELECT * FROM wa_settings');
19: while($row = mysql_fetch_assoc($result)) {
20: $GLOBALS['wa_settings'][$row['name']] = $row['value'];
21: }
22: mysql_free_result($result);
23:
24: #####
Please help!..
Many thanks in advance!.. :-)
