Fatal error: Maximum function nesting level of '100' reached, aborting!
Thread began 6/20/2011 1:23 am by Base5 Designs | Last modified 6/20/2011 1:38 am by Base5 Designs | 1580 views | 1 replies |
Base5 Designs
why is this happening how can i fix it
Fatal error: Maximum function nesting level of '100' reached, aborting! in D:\******\******\******\******\webassist\framework\framework.php on line 36
i have a framework template and applied a dynamic plug-in.
you guys do offer great support, but would be so much better if your extensions worked and i didnt need the support, as i am in a diffirent timezone, and have to wait minimum 12-24 hrs before i can continue working, its a pain it really is.
Base5 Designs
found the problem
the extension does not add the correct filename for the template...
$WA_index_1308554741097_Template = new WA_Include("../Templates{$WA_index_1308554741097_Content_Empty}/index.php");
should be
$WA_index_1308554741097_Template = new WA_Include("../Templates{$WA_index_1308554741097_Content_Empty}/index.dwt.php");
