Restricting access to users not using javascript?
Thread began 6/20/2011 2:28 am by ijk76319396 | Last modified 6/20/2011 3:47 pm by ijk76319396 | 704 views | 2 replies |
ijk76319396
Does security assist have any function that would redirect any users not enabling javascript on their browsers. I have several forms which use a java check form, however all a user would have to do is disable java to fill out the form with unwanted data. Is there anyway to do this?
No Security Assist cannot detect if the client has turned off javascript in the browser or not.
you should not rely on client side javascript form validation, you should use server side validation as a backup for when the client has disabled javascript.
ijk76319396
I placed a <noscript> line on the page that redirects to another page telling the user to enable javascript. I also used the same <noscript> and embedded a hidden file field that alters the data being inserted into the database only if the user has disabled javascript, that way if they stop the page from redirecting in the second it takes, the noscript hidden field will still alter the data being submitted. Let me know if you see any problem with this.
