Uploading Images
Thread began 6/19/2011 8:07 pm by Martin | Last modified 6/20/2011 1:14 pm by Jason Byrnes | 1210 views | 6 replies |
Martin
Uploading Images
Hi there,
Just installed and got Power Messenger working. However, I am trying to create a custom email and upload an image for inclusion in the message.
I get the following error message when I go to browse the server.
alert("MDB2 Error: no such table\nSELECT extension, plugin FROM kfm_plugin_extensions WHERE user_id=1")
Any ideas?
Thanks,
Martin
in the power messenger database, delete all tables who's name starts with "kfm_" Then try it again.
Martin
Hi Jason,
I don't know if this makes a difference, but I added power messenger to an existing Power CMS DB.
Attached is a screenshot of the DB tables.
I just want to make doubly sure before I delete anything that it will not interfere with the Power CMS DB.
Thanks,
Martin
that's fine, the kfm_ tables are the tables used by the File manager for both power CMS and Power Messenger. they will be recreated when you open the file manager.
Martin
Hi Jason,
Ok that worked for the Power Messenger.
However, I am still receiving this error for the Power CMS Builder.
error: "" could not be created
Any ideas? Or should I post in the Power CMS builder forum?
Thanks,
Martin
Martin
Actually, cancel that... I figured it out.
In the Power CMS, the path to the admin was wrong as well as I had not changed the path to the image upload folder.
Thanks again!
Martin
Great, glad to hear it is working
