Edit using the wizard
Created mapping ok and all loads fine.
I cannot see how or where the map settings can opened again in the same wizard used when first inserted.
Have I missed something?
thanks, Paul.
thanks, Paul.
see the Pro maps for Google Getting started guide on the pro maps support page:
pro-maps-for-google/
go to the Wizard Reentry section.
Thanks Jason,
Tried that, but clicking on the placeholder map does not invoke the edit mode in properties
send a copy of your page please.
perhaps try editing the body tag back to a basic tag to see if the edit option is triggered:
<body id="page5" onload="new ElementMaxHeight();">
<body>
after editing the map you can change it back.
Tried that, but no effect unfortunately.
Sadly this workaround doesn't work!
Its a frustrating one, as i desperately need to edit the current configuration
