Power Store 45 Galleries not able to load to descriptions
Hello,
When creating a new product, then adding the description when the Admin/user chooses to add a gallerie from the sites gallery db. The control window appears with no selections and no functionality. THe control pop up is available but, all information that should be populated from the db is not available thus, the admin/user is unable to add and/or use the gallery function. image of pop up is below for reference.
I thought this may be an error in overwriting files., so I too the liberty to re download the files you have posted from store 4.5 and remove data base and all files from old store to begin over. I reloaded your new files and had same problem.
(( * question: when a problem is found that is global and pertains to the files available for users to upload the powerstore 4.5, do you update those downloadable files? or do you allow the user to find the fix and add it later? I ask since I have found some update posts and I am not sure if you have updated the downloadable files for powerstore 45 with those fixes or if they have to be added after the files are downloaded? Thank you. ))
