Jyl Weeks
Thread began 6/16/2011 12:10 pm by jylweeks427004 | Last modified 6/17/2011 10:10 am by jylweeks427004 | 2245 views | 4 replies |
jylweeks427004
Jyl Weeks
I am trying to get my checkout button, update cart button, clear cart button to redirect to another page but it won't. I have told it to go to another exisiting page but it still displays an 'empty cart' shopping cart page for all the buttons. Help!!!!
send a copy of your page and a link where i can see the problem.
jylweeks427004
jyl weeks
I am just starting to install Dynamtic Suite. I created the shopping cart page and none of my buttons advance to the coorect page that they should.
Shoppingcartphp.txt
shoppingcartphp.zip
my guess is that this line is causing the problem:
//WA eCart Include
virtual("/WA_eCart/eCart1_PHP.php");
the virtual() function will cause the header() function to fail with a "headers already sent" error.
in your site definition, there is a setting on the Local Info Tab titled "Create Links relative To:". if you select the "Server" option, Dreamweaver will use the virtual() function for attaching files. If you select the "Document" option, Dreamweaver will use the require_once() function instead.
I suggest using the A"Document" option.
change that code at line 1 - 4 to:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
if you contine to have a problem, add the following code to line 1:
error_reporting
(E_ALL);
and see the following thread for details on the "headers already sent" error:
showthread.php?t=19285
jylweeks427004
Jyl Weeks
I had to change everypage to use require_one. Thanks
