Login stats
Thread began 6/16/2011 3:08 pm by info97301 | Last modified 6/17/2011 9:55 am by Jason Byrnes | 788 views | 3 replies |
info97301
Login stats
Hi
I've built a login stats page, which I'm sure worked properl before - but doesn't now! The login date in't enterd into the database (and the logout field is set as current_timepstamp on update, so I cn't use that)
The problem is the last line below:
$WA_fieldNamesStr = "MemID|IPaddress|loginDate";
$WA_fieldValuesStr = "".$row_WAATKmembers['MemID'] ."" . "|" .$_SERVER['REMOTE_ADDR'] . "|" . "current_timestamp";
At the moment, it just enters 0000-00-00 00:00:00 into the database - obviously 'current timestamp is incorrect. I've also tried now() with the same result. The MemID and the IP Address are both inserted.
Any help much appreciated.
Cheers
chris
in the insert record behavior add the following in the value for the login date column:
<?php echo(date("Y-m-d H:m:s")); ?>
info97301
Thanks Jason.
Strangely, I'd tried that without success - but when I changed things around so that the login date was current_timestamp in the database and put your code on the logout page (in the update server behaviour) it worked. Thanks again,
Cheers
Chris
glad to hear it is working.
