complex mysql join for dataassist results page
Thread began 6/16/2011 2:07 pm by Jenny I | Last modified 6/20/2011 4:52 pm by Jason Byrnes | 1431 views | 7 replies |
Jenny I
Hi
I am currently struggling to understand how I can get some values from a complex mysql join.
The values I am trying to get are people.firstname and people.lastname. This works perfectly with my first LEFT JOIN
  LEFT JOIN people ON inbox.newUserID=people.peopleID
but I do not know how I can creat/filter people.firstname and people.lastname to be assigned to my third left join
  LEFT JOIN application AS applicationperson ON people.peopleID=applicationperson.peopleID
my sql statement look like this
  SELECT inbox.inboxID, inbox.newUserID, inbox.applicationID, inbox.inboxDate, people.peopleID, people.firstname, people.lastname, people.salutationID, application.applicationID, application.peopleID
FROM inbox
LEFT JOIN application ON inbox.appilicationID=application.applicationID
I'm sure i understand what you are trying to accomplish.
you want to filter the recordset to return records where the people.firstname and people.lastname have a specific value?
if so, that is not done through a join, that is done using the where clause:
FROM inbox
WHERE people.firstname = "john" AND people.lastname = "doe"
Jenny I
Hi Jason,
The issue is that the two tables I have in my sql both have people.peopleID as foriegn keys.
so if I try to create both joins e.g.
LEFT JOIN application ON people.peopleID=applicationperson.peopleID
people.firstname and people.lastname can only refer to the first join. Is there any way I maybe using the AS operator I can create some like
people.firstname AS applicationpeople.firstname so that I can have to unique values. So
applicationpeople.firstname will be related to
and people.firstname will be related to
i think your thinking of this incorrectly.
people.firstname refers to the firstname column of the people table.
this has nothing to do with the first or second or third join.
it will always ever refer to the firstname column of the people table.
there is no reason to join the application table twice in the sql.
if you have a column in both the people and application table that is named the same, you can refer to them using the table.column syntax:
people.firstname - would return the firstname column from the people table
application.firstname - would return the first name column from the application table.
Jenny I
Hi Jason
I think my problem is similar to this and believe the solution is similar. My application table does not have firstname and lastname fields. It has a peopleID foreign key which gets the data from the people table.
showthread.php?t=18122&highlight=joins
I tried the solution by changing my join to
FROM inbox
LEFT JOIN people AS applicationperson ON application.peopleID=applicationperson.peopleID
then i created these variables
<?php echo $row_WADAinbox['applicationperson.firstname']; ?>
<?php echo $row_WADAinbox['appilcationperson.lastname']; ?>
but it didnt work
your select clause does not include the applicationperson.firstname and appilcationperson.lastname columns
change:
SELECT inbox.inboxID, inbox.newUserID, inbox.applicationID, inbox.inboxDate, people.peopleID, people.firstname, people.lastname, people.salutationID, application.applicationID, application.peopleID, applicationperson.firstname, appilcationperson.lastname
Jenny I
Hi Jason
Strangely when I run the query
the application.fisrtname and application.lastame shows in the query however people.firstname and people.lastname dissapears. If I remove the
then people.firstname and people.lastname appears in the sequel query again. I am not quite sure why this is happening.
please send a SQL dump of your tables and the full SQL so i can troubleshoot the problem using your data.
