background colour
Thread began 6/15/2011 8:06 am by WhiteJC | Last modified 6/15/2011 2:56 pm by CraigR | 908 views | 3 replies |
WhiteJC
background colour
the background colour is only being 'set' for the height of the body, how can I get the colour to go all the way to the bottom of each page?
you can see an example here...
index.php
CraigRBeta Tester
in your css page
remove the background-color from this section
html, body, div, span, applet, object, iframe, h1, h2, h3, h4, h5, h6 {
WhiteJC
that gives me colour all the way to the bottom, however the body is now grey and/or the background colour
CraigRBeta Tester
not entirely sure on the result you are looking for.
but you could try.
change the background-color of outerwrapper to #fff
remove the background image from this div
change the background color of the leftcolumn 1 div to #fff or delete it altogether
if you are unsure about changing the code directly, if you are using firefox as a browser, use firebug and you can see what the changes will be like
