HELP - How to clear the URL PAR
Thread began 6/14/2011 4:20 pm by hbibizadeh396670 | Last modified 6/16/2011 10:32 am by Jason Byrnes | 1749 views | 6 replies |
hbibizadeh396670
I built a user registration system for my eCart.
However I have a small issue.
I am using a simple show if which allows me to show an error message if the username is already taken.
<?php if(isset($_GET['BadUserName']) && $_GET['BadUserName'] == "1") { ?>
<div id="RegFailDIV">UserName is Taken. Please Try Another.</div>
<div id="LoginFailDIV"></div>
<?php } ?>
The issue is cause by the fact that my form can fail for multiple reasons. For example captcha is wrong.
The issue arises when the username box displays, if a user re types the form with a available username, submits the form, if the form fails for a different reason, and returns to the page, the username box still appears, because the URL par has not been removed.
Could you tell me how to clear the URL PAR when the form is re-submitted.
Also,
I need to make my passwords encrypted.
Although I know how to do this and make it work with my login and registration pages. I do not know how to make email password work. This is because the email password would email the encrypted password in its default state.
Could you tell me how to do this.
Thank you.
hbibizadeh396670
Is this possible
add the following code just before the form tag on the login page to strip the BadUserName querystering variable if it exists:
if(isset($_SERVER["QUERY_STRING"])) {
$arrQS explode("&"$_SERVER["QUERY_STRING"]);
    foreach(
$arrQS as $k => $v) {
        if(
$v == "BadUserName=1") unset($arrQS[$k]);
$_SERVER["QUERY_STRING"] = implode("&"$arrQS);
for the email pass word, edit the email passwrd server behavior, remove the reference to the password database column, then click the plus button and select the NewPW session variable.
hbibizadeh396670
Ok,
I have made the Email PW work fine. (Thank you)
However I still cannot fix my URL Issue. And I did add your code above.
To help you, please use the below link and follow my instructions to re-create my issue.
Registration.php?BadUserName=1&requsername=AshleyBibizadeh
I have included the URL Par which is causing the problem in the URL. This way the UserName is not available Message will show immediately for you.
To re-create the problem, please fill in the form fields with values, and a different username which is available (Example sdfhsd) and enter a WRONG captcha code.
This means that although the UserName is available, and the form has returned to the page for a different error.
It still displays the UserName Error Message. (Which Is Ny Issue)
This is because the URL Par is still present in the URL.
Could you please help me solve this.
Thank you in advance.
did you add the code from my previous reply?
Please send a copy of your page so i can see the code.
hbibizadeh396670
Sure.
I added the code, but have not had any luck.
Could you delete the attachment from this post when you have it?
Thank you.
I see, change line 73 - 79:
$editFormAction
$_SERVER['PHP_SELF'];
if (isset(
$_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" htmlentities($_SERVER['QUERY_STRING']);
$editFormAction
if (isset(
    foreach(
        if(
$strQS implode("&"$arrQS);
$editFormAction .= "?" htmlentities($strQS);
