shipping
Thread began 6/14/2011 5:21 am by QuiruNet | Last modified 6/15/2011 1:32 pm by Jason Byrnes | 1322 views | 3 replies |
QuiruNet
shipping
here in spain we can not connect to special shipping company, and i want to create a data base to create de shipping cost.
Is better to build the data base, or use the calculator shipping in the icart window.
for example i nedd something like this:
0-10 kg = 10 €
11- 20 kg = 18 €
21 - 30 kg = 25 €
31 - 40 kg = 35 €
etc......
if the shipping rates dont for each weight range aren't going to change, then define the rules directly in the eCart object.
If the rates for each weight range will change frequently, then you would want to use a database
QuiruNet
define the rules
the weight ragen aren´t goint to change.
I don´t kwon to use the shipping rates for too many weight, can you show me. ..thanks
in the eCart object, go to the shipping tab.
you will need to create a shipping rule for each weight range, they will all be set up basicly the same, the only change will be the vlaues for weight and the flat rate charge.
for example the first one would look like:
Name "0 - 10KG"
Triggers:
Subtotal For any Column:
If the SubTotal for column 'TotalWeight' is ">" a value of "0"
AND
If the SubTotal for column 'TotalWeight' is "<=" a value of "10"
Charges:
Flat Rate charge of "10"
