Error Ecart with argument
Thread begun 6/12/2011 9:38 am by minhtandoan421310 | Last modified 3/02/2012 2:26 pm by Jason Byrnes | 4153 views | 7 replies |
minhtandoan421310
Project is 3 page.
1.index.php (show quick-cart)
2.chitiet.php?idSP=...(insert add to cart button)
3.cartdetail.php(updateable cart)
run---> chitiet.php?idSP...---> add to cart button---->cartdetail ----oki
---->cartdetail-----error (Warning: Missing argument 3 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in D:\AppServ\www\testEC\WA_eCart\WA_eCart_Definition_PHP.php(491) : eval()'d code on line 1 and defined in D:\AppServ\www\testEC\WA_eCart\eCart1_PHP.php on line 236
Warning: Missing argument 4 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in D:\AppServ\www\testEC\WA_eCart\WA_eCart_Definition_PHP.php(491) : eval()'d code on line 1 and defined in D:\AppServ\www\testEC\WA_eCart\eCart1_PHP.php on line 236
Warning: Missing argument 5 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in D:\AppServ\www\testEC\WA_eCart\WA_eCart_Definition_PHP.php(491) : eval()'d code on line 1 and defined in D:\AppServ\www\testEC\WA_eCart\eCart1_PHP.php on line 236
Warning: Missing argument 6 for eCart1_ItemDefinition::eCart1_ItemDefinition(), called in D:\AppServ\www\testEC\WA_eCart\WA_eCart_Definition_PHP.php(491) : eval()'d code on line 1 and defined in D:\AppServ\www\testEC\WA_eCart\eCart1_PHP.php on line 236)
Help me, please!
send a copy of your 3 pages and the WA_eCart\eCart1_PHP.php in a zip archive and a URL where i can test them please.
minhtandoan421310
Please, help me. I post (site+noithat.sql) Thanks!
I am not able to reproduce the issue with the files you provided, but looking at the screen shot again, I can see that you have a number of items in the cart before you start to see this error.
This makes me think the error is caused by the data being added to the cart fpr either the name or description.
to trouble shoot the problem, look at the database for the item that causes the error to occur and change the name or description to something else.
minhtandoan421310
I figured out this problem. Because I used type UTF8( code Vietnamese). Encoding 2 file eCart_PHP.php and WA_eCart_Definition_PHP.php is utf-8. It's Oki :)).Thanks for hints to help me find this bug.
ok, glad to hear it is working.
morganbeat297916
How to encode utf8 file. i has same issue
open the file in dreamweaver, then go to Modify -> Page Properties, on the Title / Encoding tab you can change the pages encoding to utf-8 and make sure the Include Unicode signature option is not checked.
