PowerCMS and SA2
Thread began 6/11/2011 7:12 pm by npizzola365988 | Last modified 6/16/2011 7:08 am by Jason Byrnes | 1672 views | 5 replies |
npizzola365988
PowerCMS and SA2
I have installed Security Assist 2 on my website and when I went back to the CMS I get thie following error:
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /var/www/clients/client16/web31/web/webassist/security_assist/helper_php.php:28) in /var/www/clients/client16/web31/web/WA_SecurityAssist/Helper_PHP.php on line 46
I commented out the require_once( "../WA_SecurityAssist/Helper_PHP.php" ); line in the \WA_CMS\WA_CMS.php file that I found on the forums and it still gives me the error.
Is there anything else I can do?
there are two require once lines on the page for security assist, one to attach the:
file, and another to attach the
one of those will need to be commented out, probably comment the one for the WA_SecurityAssist/Helper_PHP.php file
npizzola365988
PowerCMS and SA2
Jason - Thank you for getting back to me.
I can't find another instance of the require_once command.
I've included the file with a zip extention to see if I'm missing anything.
WA_CMS.php.zip
the error is not occurring in the \WA_CMS\WA_CMS.php file.
it is occurring in the file you have open in the browser when the error occurs, that is the file that you should be looking for the 2 require once lines in.
npizzola365988
Got it!
I found that I had to comment out the "webassist/security_assist/helper_php.php" instead of the "WA_SecurityAssist/Helper_PHP.php" and then things started working again. THANK YOU for setting me in the right direction.
you're welcome.
