pdf from pcms content
Thread began 6/10/2011 5:40 am by gruant2000381341 | Last modified 6/10/2011 12:02 pm by Jason Byrnes | 1022 views | 1 replies |
gruant2000381341
I know you don't write custom scripts, but I was wondering if anyone knew of an easy way to output a pdf from cms content.
I have a form that I want in pdf format, but the contents of that form will need to change quite often. So I put my form contents in powerCMS, and now I just want when a user clicks the 'get pdf' link, it will draw from pcms and create that pdf in the browser. I don't want to create static pdf's in my dir....just output them.
you would to manually code the process to generate the pdf, here is a tutorial i found through google:
generate_pdfs_dynamically_with_php/
it should be possible to output a power cms content area in the pdf by adding the power cms code in the code that generates the pdf.
