error starting floater:
Process type "undifined" not found.
Got this error after I filled in the blanks and pressed ok.
Using CS 4
Using CS 4
Delete the Dreamweaver Cache file from the users configuration folder:
Hi Jason,
Done the delete cache thing after closing DW4. It still comes up with the same problem
I followed instrruction except path does not exist.
path to the file to delete was
C:\Users\Larry\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
C:\Users\Larry\AppData\ has 3 options. Local folder LocalLow folder or Romingfolder.
the 2 local folders do not have the path.
Im using win 7 and dreamweaver cs4
Still have same error message
Larry
Hi and god morning, i got the same Error just now. Wut solution on this problem do exsist?
/Morgan :)
Ty Jason, the new file fixed my problem.
//Morgan :)
I am also receiving the error starting floater message when attempting to implent this on my site. I have cleared the cache restarted both DW and my PC with no difference in behaviour. Please help.
Thanks,
Gary
