Gap Between Gallery and PowerCMS Content
Thread began 6/09/2011 2:09 am by PimpMyHoodie | Last modified 6/20/2011 12:42 pm by Jason Byrnes | 1275 views | 3 replies |
PimpMyHoodie
I know this is going to be a dumb question (and the answer probably simple!) but can someone please tell me how to add a space between the very bottom edge of my gallery and the text that starts on the next line of my website page?...
the page is built using PowerGallery, which is followed by content from PowerCMS..
I'd like there to be a gap (is it called a line break?) between the two but I'm not sure how to do it!..
here a link so you can see:
artists.php
(Basically I'd like there to be a gap between the very bottom of the top gallery and the words "Artists - Derek Harris" on the next line!)
And here's the code:
InstanceBeginEditable name="MainBodyEditable" -->
<p>
include('/home/armadaga/public_html/cms/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_localhost, $localhost, '3.1 - Artists - Robert Lenkiewicz' , '3.1 - Artists - Robert Lenkiewicz');
$pg_id = '1';
$pg_theme = 'light';
include('/home/armadaga/public_html/gallery/galleries/ribbon_fullsize_lightbox/index.php');
echo WA_getCMSContent($database_localhost, $localhost, '3.2 - Artists - Derek Harris' , '3.2 - Artists - Derek Harris');
</p>
<p>&nbsp;
Many thanks in advance!.. :-)
yes, it's called a line break, the code for a line break is;
<br />
add a br tab between the gallery code and the power cms code:
for example:
$pg_id = '1';
<br />
<br />
PimpMyHoodie
Hi Jason,
Thankyou for your reply........
However it still doesn't work where I need it to!.. :-(
The problem is that it (the line break) works after each section of text from PowerCMS but doesn't seem to have an effect Directly after each gallery and before the next section of PowerCMS which is where I really need it!
I'd like there to be a gap between the very bottom of every gallery and title of each next "artist" below, but as you can see (below) it still makes no difference!..
here is the code:
<p>
<br />
<br />
<br />
<br />
$pg_id = '1';
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
$pg_id = '2';
<br />
<br />
<br />
<br />
echo WA_getCMSContent($database_localhost, $localhost, '3.3 - Artists - Jeremy Davies' , '3.3 - Artists - Jeremy Davies');
<br />
<br />
<br />
<br />
And here is the link:
artists.php
Please help!.. :-) thanks :-)
trey using empty P tags in place of BR tags:
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p>
instead of:
<br />
<br />
<br />
<br />
