CSS Menu Writer and Lightbox
Thread began 6/08/2011 4:02 am by Nathon Jones Web Design | Last modified 6/08/2011 7:39 am by Jason Byrnes | 878 views | 2 replies |
Hi. We have Lightbox 2 installed on a website we're developing, which also has a CSS Menu Writer menu.
When we select an image that has the Lightbox effect applied, everything but the CSS Menu Writer fades out.
Is there something in the css I can add that will ensure that the CSS Menu Writer menu also fades out?
Here's an example of this. Just click the "Factors Suite" image, below the main header image, to see the problem:
hotel-rooms-portpatrick.asp
Hope someone can help with that. Thanks.
N.
found it...
Oops, sorry, I should have searched the forum first. Here is the answer, from another post:
in the menu.css file, change:
ul#cssmw li {
background-image: none;
float: left;
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
z-index: 100;
ul#cssmw li {
float: left;
padding: 0 0 0 0;
position: relative;
z-index: 1;
Thank you Jason.
N.
glad to hear it's working.
