Blank Value in Search drop menu
Thread began 6/07/2011 5:04 pm by Brad Lawryk | Last modified 6/08/2011 10:15 am by Jason Byrnes | 633 views | 1 replies |
Brad Lawryk
I have a data assist search and results set up and of coourse it all works fine. But in one of my search fields I have a drop menu to select province. I would like to add an option to the menu to select all ... or in other words if I search by city, I want it to come up regardless of province. I hope I explained that well enough.
I'm not 100% sure I follow what you are asking.
But if you want to add a select all list option, just make sure that the option has a blank value:
<option value="">Select All</option>
Dreamweaver wont add the blank value attribute if you leave the value blank, instead it leaves the value attribute off completely, so you;ll need to add that in.
