Redirect issue on insert and update
Thread began 6/07/2011 11:06 am by kelly1398725 | Last modified 6/08/2011 9:22 am by Jason Byrnes | 968 views | 5 replies |
kelly1398725
Hello everyone!
I need some help with redirect after an insert or update on pages created with DA. I have installed the library.php as directed from sticky and other threads I have read here, but I am still unable. I can redirect with local testing, but on remote server I get page not found. I have also tried the fix given on the download center for DA with no result.
Does anyone have any idea why I could redirect locally but not on remote server? Do I need to change any settings on my php.ini file on remote or have to allow anything? Other insert pages not created by DA redirects fine.
Unfortunately for me, I have created alot of insert and update pages including modifications before uploading to test on remote server. Before I start over again, I would be grateful if anybody had similar problems and could offer some suggestions.
Thanks.
DarylBeta Tester
Hi Kelly
Silly question I expect, but is the page that you are redirecting to, uploaded to the server?
Is the right url in the redirect part of the code?
$WA_redirectURL = "URL Here";
kelly1398725
Hi Daryl,
Thanks for you reply. Not a silly question. The pages being redirected to are all uploaded and the url is right there with the variable. Securityassist pages and others created with WA redirects with out any problems.
Thanks Jason for the support ticket. I would follow up on that.
kelly1398725
Solved
Hi all,
My issue is solved. After updating and uploading the new library.php file, I should have cleared the browser cache before further tests. My Host suggested that and that did the job.
Thanks for your interests.
excellent, glad to hear it is working.
