Why both client and server-side validation?
Thread began 6/06/2011 10:41 pm by James L | Last modified 6/07/2011 9:36 am by Jason Byrnes | 1031 views | 1 replies |
James L
I set up client side validation, works ok, but server side looks so much better. I set up part of server side val, but when I test it locally it only shows client side error messages. The "getting started in Val toolkit" says I should do both, but if I use server side why do I need client side? and as my test indicates, client side rules, how can I now remove client side val code and just use server side code so those cool red error messages appear?
Also it seems like there is a way to make the validation process stop and revert back to the checkout form at each step of the way, rather than waiting until the final checkout button is selected and many errors are listed. How do I do that?
Client side validation is performed in the client browser using Javascript. The down fall of Client validation is that it can be disabled if javascript is turned off in the browser.
Since Server Side validation is performed on the php server, the client cannot get around it.
I recommend always using server side validation.
you can remove client side validation by opening the bindings panel, go to Windows -> Bindings.
In the tag selector, select the form tag, then in the bindings panel select each validation and click the remove button.
this is done using client side validation, applied to the onBlur action of each form element.
