SA 2 has played havoc with CMS
Hi
Since installing SA 2 I can now no longer load CMS login or pages and pages I have SA on just throw error Http Error 500.
Very despeerate for help on this one.
Mike
Hi
Mike
Hi
Sorted what I thought was all of this with Ray but have since found another issue.
Ive added a page and no matter what I do SA will not validsate a user as being logged in.
Any ideas?
Mike
how is the Administrator access rule defined?
on the users_login.php page, add the following code after the <body> tag:
<pre><?php var_dump($_SESSION); ?></pre>
this will write all of the sessions that are set and their values to the page to compare against the settings for the Administrator access rule.
Hi Jason
This is whats returned
array(2) {
["WAENCRYPTEDRETURNUSED"]=>
bool(false)
["WAENCRYPTEDRETURNSUCCESS"]=>
bool(false)
Strange thing is I have pages pre SA 2 that work and any page that is now added does not.
I am using Power CMS too in case you wondered.
Mike
can you send a copy of one og the pre SA2 pages that does work so I can compare the code?
Hi Jason
2 files Gallery_edit_image.php is pre SA2 and testpage is a plain page that is post SA2 and does not work.
Ill attach the login page also.
Mike
