In group? Confusing ...
Thread began 6/06/2011 4:05 am by info4753 | Last modified 6/06/2011 2:15 pm by Jason Byrnes | 719 views | 3 replies |
info4753
How is the compare to function "In group" in the edit access rule meant to be handled? Against which value do I have to compare it?
I want a member with AccessLevel = 3 be a administrator and being redirected to the admin folder after login.
So I create a session at the login and place the Administrator rule:
Allow: Value: <?php echo $_SESSION['ALID']; ?> Criteria: = Compare to: 3
(I guess that the entered value of 3 is not correct, I'd need to compare to the database field value, but I'm getting an error when trying to select anything, see corresponding thread.)
On the Access Pages Manager I select the index.php file in the admin folder (selecting the folder itself is not working, see corresponding thread) and choose grant access if Administrator rule.
If I do understand it right then a user with Access Level = 3 should be granted access to the files within the admin folder. Is this correct?
Actually it's not working, I do not get granted access for memners with access Level = 3...
Do I need the Access Groups Manager for this at all?
in group allows you you to specify a group of values, i.e. 3, 4, 7, 9 to allow access. where you are only using a single value of 3, you do not need to use the in group comparison.
Does you login page set the ALID session?
On the login page, double click the Authenticate user server behavior, go to the third step, and make sure that the ALID session is being set.
For the other issues:
you have another thread that I started a ticket for, we will look into this error in that ticket as well.
info4753
This problem has been fixed with the current update. Thanks Jason.
OK, glad to hear the issue is fixed.
