Error with Edit access rule
If I click on "compare to", I get the following error:
you have another thread that I started a ticket for, we will look into this error in that ticket as well.
I am using SA2 on Windows, DW CS5.5 and getting the same error when trying to Define a new access rule. Clicking the 'compare to' lighting box throws the error
have you updated to the new 2.0.1 version that was released on Friday?
make sure to uninstall version 2.0.0 from the extensions manager before installing the newer 2.0.1 version that is available for the download center.
