Validation or Validation Toolkit?
Thread began 6/06/2011 3:15 am by info4753 | Last modified 6/06/2011 2:16 pm by Jason Byrnes | 769 views | 3 replies |
info4753
Under Server Behaviours > WebAssist
I have:
Validation
Validation Toolkit
With the same submenus. Which one do I have to use ... ?!
I do like your extensions but with every new release of an extension the complete build-up is more confusing. Please consider a complete suite, with a clean installation and a center control system (versions, languages, server configuration).
you should not have validation toolkit installed with Security Assist 2. If you have validation toolkit installed, you should uninstall both validation toolkit and security assist, then install Security assist 2 again.
info4753
I did not install it by myself. I've installed:
DataAssist 2.0.8
SecurityAssist 2
FormBuilder
By the way, if I install FB after SA2 I get a more or less stable FM, but SA is causing errors. If I install SA2 after FB, FB is causing troubles.
I haven't come up to test DA2 so far ...
Add this information to the ticket I created for you earlier and we will look into this over the phone.
