Multiple record update not working
Thread began 6/05/2011 11:58 pm by enquiry272230 | Last modified 6/06/2011 12:45 am by enquiry272230 | 792 views | 1 replies |
enquiry272230
Trying a simple test prior to trying to use on website.
Very basic update multiple attempt not working at all.
Appreciate your analysis.
Page Code follows:
<?php require_once('Connections/cingular.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_cingular, $cingular);
$query_rs_move = "SELECT * FROM items2 ORDER BY OrderBy ASC";
$rs_move = mysql_query($query_rs_move, $cingular) or die(mysql_error());
$row_rs_move = mysql_fetch_assoc($rs_move);
$totalRows_rs_move = mysql_num_rows($rs_move);?>
// WA DataAssist Multiple Updates
if (isset($_POST["submit"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_ItemID");
$WA_connection = $cingular;
$WA_table = "items2";
$WA_redirectURL = "move.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "ItemID";
$WA_fieldNamesStr = "ItemName|itemDiam|ItemSKU|OrderBy";
$WA_columnTypesStr = "',none,''|none,none,NULL|',none,''|none,none,NULL";
$WA_connectionDB = $database_cingular;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("name", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("diam", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("SKU", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("sortorder", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form action="" enctype="multipart/form-data" name="form1">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rs_move){
<table border="1">
<tr>
<td>ItemID</td>
<td>ItemName</td>
<td>itemDiam</td>
<td>ItemSKU</td>
<td>OrderBy</td>
</tr>
<?php do { ?>
<tr>
<td><input type="hidden" name="WADA_RepeatID_ItemID_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_ItemID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_move["ItemID"]; ?>" />
<input name="ID_<?php echo $RepeatSelectionCounter_1; ?>" type="text" value="<?php echo $row_rs_move['ItemID']; ?>"/></td>
<td><input name="name_<?php echo $RepeatSelectionCounter_1; ?>" type="text" value="<?php echo $row_rs_move['ItemName']; ?>" /></td>
<td><input name="diam_<?php echo $RepeatSelectionCounter_1; ?>" type="text" value="<?php echo $row_rs_move['itemDiam']; ?>" /></td>
<td><input name="SKU_<?php echo $RepeatSelectionCounter_1; ?>" type="text" value="<?php echo $row_rs_move['ItemSKU']; ?>" /></td>
<td><input name="sortorder_<?php echo $RepeatSelectionCounter_1; ?>" type="text" value="<?php echo $row_rs_move['OrderBy']; ?>" /></td>
</tr>
<?php } while ($row_rs_move = mysql_fetch_assoc($rs_move)); ?>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rs_move && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<input name="submit" type="submit" value="submit" />
</form>
</body>
</html>
mysql_free_result($rs_move);
enquiry272230
Got it Working
Got it working now.
The repeat region code was not inserted correctly by Data Assist.
All sorted, although it cost me time.
