Stuck at Please Wait when editor added
Thread began 6/05/2011 3:00 pm by Sally | Last modified 6/07/2011 10:26 am by Sally | 1045 views | 2 replies |
Sally
I have a form that sends to a recordset that works fine. But when I add the HTML editor to the textarea of the Comments field, it stays stuck at Please Wait with the circle thing.
All I did was select the form element, insert the editor, and upload the file. I don't think there are any other supporting files I need to upload to the server as I did this process with a similar form and it worked fine. The major difference between the two is the other form also uploaded its attachment on the server and inserted the name into a database. This one just sends the attachment to everyone, but it's not archived.
If I overwrite the html editor version with a non-html editor version, it works fine. As soon as I add the editor, it doesn't. The other files I've done this with all work. I've attached it if it helps.
Any help would be appreciated. Thank you.
Email_Residents.zip
Sally
Thanks for your help, Jason. And also to Ray who followed up.
Just as an fyi to anyone else who may have this, the problem was related to a Spry validation on the textarea. Apparently when adding the HTML editor to a textarea with validation, it changes things and causes some kind of javascript loop so it can't proceed as normal.
I'm probably doing a horrible job of explaining it but the bottom line is after removing the Spry validation language for the textarea (looks something like: var Comments_Spry = new Spry.Widget.ValidationTextarea("Comments_Spry");) the form works just fine.
Thanks again to you both for great WA support.
