How to restrict rows in ItemLongDescription in search results page.
Thread begun 6/05/2011 5:59 am by richard412075 | Last modified 6/07/2011 5:18 am by CraigR | 5380 views | 12 replies |
richard412075
Not sure if anyone can help.
I am trying to restrict the ItemLongDescription row count to < 5 in the "Search - Results" page of dataAssist.
I can't find either a Constant or other value, and it just seems to output everything onto the search results Long Descrition, even though it puts a 'More' link that takes you to the Item detail.
Any ideas?
Many thanks, Richard....
CraigRBeta Tester
Are you trying to restrict the number of rows returned to the first 5, or are you having an issue with pagination ?
If pagination, you can open up the repeat region server behavior and choose to show all records or choose to show 5 (or whatever) records at a time
richard412075
Hi Craig,
I am trying to restrict the number of rows that the following call retrieves from the database:
<?php echo $row_WADAitems["ItemLongDesc"]
I think this is being set by
$row_WADAitems = mysql_fetch_assoc($WADAitems);
Any ideas?
Thanks for your help...
Regards, Richard.
CraigRBeta Tester
Hi Richard.
Sorry, I'm still not clear if you are trying to restict your recordset to 5 rows per page, or limit the output to the first 5 rows only.#
Can you zip and upload your page ?
richard412075
Hi Craig.
My fault, I am not being all together clear....
If you go to the following link:
garden.php
Look at the descriptions of the products (on the first page it probably starts:"this substantial frame" etc...) I need them to go as far down as the image (so about 6 columns down).
I will upload garden.php as well so you can see the code...
Thank you for the help with this... I just cant seem to get my head around it...
CraigRBeta Tester
Hi, sorry for the delay in replying.
I think I understand, you have a field called itemlongdesc which contains a long text string, which you want to shorten , so it appears in 5 lines in the space provided. ?
There is a php function called strlen which you can use to return a partial string, which may give you what you want.
You may need a bit of trial and error to get it to fit to 5 lines.
I also have a function to trim a partial word from a string, which makes it look a bit neater, when you add the ...more ellipsis
richard412075
Hi Craig,
Strlen returns the length of a string.
Basically what is happening is that I am using a copy of a WA DataAssist search results page to view products summaries. I need the summary to stop at about 5 columns, and cant find any variable or constant that defines this within the PHP produced by data assist.
Anyone else try the same thing?
Going to have to delve in to the PHP I think, but its not my strong point.
Any help would be hugely appreciated.
Kind regards, Richard.
CraigRBeta Tester
Sorry, it was late last night.
The php function you want is substr()
You can find out more about it here...
func_string_substr.asp
richard412075
Hi Craig,
SubStr will trim the length of a string but I think its the way that the Web Assist command that relates to: $row_WADAitems = mysql_fetch_assoc($WADAitems); is what needs chaning to restrict the number of rows that are returned.
Changing the string length would limit the width of what is returned into the page. I am looking to restrict the number of rows...
Regards, Richard.
richard412075
OK, think I have worked it out, although I have got to write the PHP to fix it yet.
I was (wrongly) thinking that the "mysql_fetch_assoc" was returning an associated array, when in fact it is simply returning a text srting as it only returns one element.
I will therefore use the explode command (with a delimiter of say <br>) and then use only the first 5 elements of that array.
Thanks for the help Craig...
