Domain name change from .org to .net
Thread began 6/04/2011 1:52 pm by jcav26033 | Last modified 6/06/2011 12:12 pm by Jason Byrnes | 844 views | 1 replies |
jcav26033
A client using PowerCMS version 1 lost the right to their domain and need to go from a .org to a .net. All files remain on the same server, only the domain extension is changing. What, if anything, do I need to do to be sure the CMS continues to function correctly?
As far as I have seen in the config file in connections, nothing is referenced by the domain extension. Anything I need to watch out for other than hard-coded URLs they may have entered in their own content?
I dont believe there should be any issues if only the domain name is changing, but the files are staying on the same server. There should not be any problems with this.
