SA2 problems
Thread begun 6/03/2011 9:53 pm by keith.mears422260 | Last modified 6/06/2011 9:12 am by Jason Byrnes | 3560 views | 5 replies |
keith.mears422260
SA2 problems
I have had terrible trouble with SA 2 and unable to create any full set of pages that worked without errors, everything from Javascript errors to unable to fit on a page (my page is 1024px wide), just too many to write down! Some of the javascript errors were 5 - 6 entries to the pop up screen, I also have the word undefined at the top of each page.
Getting know where I have had to uninstall SA 2 and re-installed SA 1, then more problems as loading Dreamweaver brought up loads of error messages, uninstalled Form tool kit and form builder the main theme of the error messages and reinstalled the lot but now still get "Unable to find file WA_SiteToolsV2.HTM in the Configuration/Floaters directory.” The floater will not be shown" on loading Dreamweaver. Tried using SA 1 and find 'Remember' buttons do not work any more so have now uninstalled and reinstalled Cookies toolkit 3, error message still the same when opening Dreamweaver.
Just in case your wondering, I did uninstall SA 1 before installing SA 2 and have removed MacFileCache.dat from the Dreamweaver 4 & 5 folders as described in your Common installations Issues guide.
Hope you can make some sense of this.
Morgan
Hi, try rename your Configuration folder ex. Configuration_OLD, Start Dreamweaver and it will recretate the Configuration folder as a clean one, Close DW, start extention manager remove all extentions.
Cleare the cache.
Don´t install FB2, but install Tool Kit, Don´t install Cookies Toolkit (u have that in AS2), and install other extentions as u like, last u install AS2.
I see u using Mac, not sure where to find the Configfolder on a Mac, maybe you know els do a search for it.
Hope this helps you out a bit.
//Morgan
keith.mears422260
SA2 Problems
Found the Configurations folder in the Applications folder and then Dreamweaver CS5 folder, did as suggested and dreamweaver crashed when I tried to restart and did not try and create and new configurations folder. Renamed configurations folder as was now loads but I still get the same error messages on start up. Have attached the error messages.
Morgan
Hi agian, So that rename the folder don´t work on Mac, hmm, then i don´t know.
The floater error u get is after AS2 is uninstalled, i got that too on my Windows 7, After i uninstalled Form Builder and then AS2, but the error sorted it self out after i reinstalled AS2 with out Form builder installed.
Do a search on the Configfolder for mac, in windows the Configuration folder is in
C:\Users\User_name\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration
And DW recreate the Configfolder if if finding its missing.
I found this for you, As it looks Do Not Rename the Configuration folder that is in the Application folder on your Mac, it should be in your Profil folder.
ex. Mac OS X: Macintosh HD:<username>:Library:Application Support:Adobe:Dreamweaver CS4:<language>:Configuration
Heres a link: 417116
Hope this helps
//Morgan
keith.mears422260
SA Problems
Thanks Morgan, appreciate your interest and help. Hope someone from Webassist looks at my problems and can offer some advise.
info4753
This post has been deleted.
keith.mears422260:
Do not rename the configuration folder under the applications folder, this will break Dreamweaver. Only rename the configuration folder under the users profile, for help finding the users configuration folder see the "common installation issues" faq.
