Changing size of text area
Changing the size of the text area is not working. If I change from "large" to "small" and save the preset, "small" is not updated in the page. It always adds: class="formTextarea_Medium"
I am not able to reproduce this.
What version of Dreamweaver?
What OS?
can you export the preset and attach it to your post so i can try to reproduce using your preset.
DW 5.5, Mac 10.6.7 I get the fowwoling error when I try to export the preset: ... but export worked ...
Preset of the contact form:
<wa_field_group name="Kontaktformularfelder 2">
<wa_field_line>
<wa_field_column>
<wa_field_set_validation>Bitte tragen Sie Ihren Vor- und Nachnamen ein.</wa_field_set_validation>
<wa_field_reference src="Text_Large.xml" label="Name" validation="{ required: true, type: 'none', format: null, minChars: null, maxChars: null, minValue: null, maxValue: null }" serverValidation="required" spryValidation="none" continueLine="false" elementName="Full_Name">
</wa_field_reference>
</wa_field_column>
</wa_field_line>
<wa_field_line>
<wa_field_column>
<wa_field_set_validation>Bitte geben Sie eine gültige E-Mailadresse ein.</wa_field_set_validation>
<wa_field_reference src="Text_Large.xml" label="E-Mailadresse" validation="{ required: true, type: 'email', format: null, minChars: null, maxChars: null, minValue: null, maxValue: null }" serverValidation="email" spryValidation="email" continueLine="false" elementName="Email_Address">
</wa_field_column>
</wa_field_line>
<wa_field_line>
<wa_field_column>
<wa_field_set_validation>Bitte tragen einen Text in das Anfragefeld ein.</wa_field_set_validation>
<wa_field_reference src="Textarea_Medium.xml" label="Ihre Anfrage" validation="{ required: true, minChars: 10, maxChars: null }" serverValidation="required" spryValidation=", { minChars:10 }" continueLine="false" elementName="Anfrage">
</wa_field_column>
</wa_field_line>
</wa_field_group>
Looks like Textarea_Medium.xml is not been changed to Textarea_Small.xml
I've also attached the complete preset.
