Error when securing page
Thread began 6/02/2011 10:58 am by gdavis421484 | Last modified 6/20/2011 9:32 am by Jason Byrnes | 3520 views | 15 replies |
gdavis421484
I have built a php page that contians just a form. The pupose of the page/form is to send emails to a list of people held in an Excel file.
This works - BUT - when I secure the page using Security Assist - the form will no longer open - I get a 500 error.
In the same folder is an error log to the effect:
[02-Jun-2011 18:41:53] PHP Fatal error: Cannot redeclare wa_striptags() (previously declared in /home/xxxxxxxx/public_html/webassist/security_assist/mail_php.php:268) in /home/xxxxxxxx/public_html/webassist/email/mailformatting_php.php on line 345
I am using
DW CS5, on Vista, and have the following webassist extensions:
SA2, Forms Toolkit, Data Asist, HTML Editor,ecart, Universal Email, cookies toolkit
Following instructions from Jason re. an earlier problem, I un-installed SA2 and cookies toolkit, deleted the DW CS5 .dat file, then re-installed SA2 (but not cookies toolkit).
I still have the problem.
Any suggestions?.
here is an updated copy of the webassist/security_assist/mail_php.php file that should correct the issue.
mail_php.php.zip
gdavis421484
I think you sent the wrong file?
Thanks Jason
BUT - the file you sent is called 'HelperPHP.php' not the one you mentioned (mail_php.php).
Please can you clarify if I am to replace 'HelperPHP.php'?
I just double checked, the file in the previous message is indeed the correct mail_php.php file.
gdavis421484
Unfortunately - Did not fix the problem
Thanks for sending the file, sorry for the confusion.
I replaced the mail_php.php in the webassist/email/ folder.
This made the page give a 500 error even if no security was applied.
Error:
[03-Jun-2011 09:36:44] PHP Fatal error: Cannot redeclare wa_securityassist_getemailarray() (previously declared in /home/xxxxxxxx/public_html/webassist/security_assist/mail_php.php:3) in /home/xxxxxxxx/public_html/webassist/email/mail_php.php on line 32
I have therefore put back the original mail_php.php file - so at least I can use the page with no security applied.
Any further help will be greatly appreciated
info97301
Hi Jason
I get the same error - thought it would have been written out of the code after so long!
Using Win7, CS4, Sec Assist 2.0.0, Universal Email 4.0.1
I have a form on a page sending email to selected recipients via a checkbox.
Fatal error: Cannot redeclare WA_StripTags() (previously declared in C:\xampp\htdocs\site\webassist\security_assist\mail_php.php:268) in C:\xampp\htdocs\site\webassist\email\mailformatting_php.php on line 345
If I remove the SA access restriction, the page loads fine. I haven't had chance to test the email yet, as this is on a local machine.
Cheers
Chris
an update to Security Assist 2.0.1 was released just yesterday that should correct the issue, it is available for download from the download center.
remember to uninstall the current version of security assist from the extension manager before installing this newer one.
info97301
Hi Jason
I've installed the new version, but it hasn't made any difference - I still get the error:
I did uninstall v2.0 first. I have alse deleted the dat cache file.
Cheers
Chris
did you recreate the pages? You will recreate the security assist pages using the new version to update the code.
