A rather desperate attempt to get a stable system working
Thread began 6/02/2011 5:16 am by A Sound Design | Last modified 6/02/2011 6:54 am by Jason Byrnes | 961 views | 3 replies |
A Sound Design
As the title says it I have had weeks now of trying to get a stable working environment with Dreamweaver CS4 and Super Suite. Numerous crashes, conflicts etc etc. So I went to the extreme of uninstalling the whole Adobe Creative Suite Web Standard and then re-installing just WebAssist extensions to see if this makes any difference.
I have started by installing CSS Form Builder 2.0.1 (HTML Editor Compatibility Release) first. The blurb about it says:
Features also found in CSS Form Builder 2
- Universal Email
- Digital File Pro
- HTML Editor
- Validation Toolkit
To minimise conflicts it seems logical to me to only install what is needed. From what I see here it seems that by installing this 1 extension I don't need to install Universal Email, HTML Editor or Validation Toolkit. Can someone please confirm with a definitive answer that this is the case. If these extensions are part of FB 2 then is there any need at all to install the others mentioned above, ie. to enable using HTML Editor for a form that was not created using WA Form Builder ??
Thanks in advance.
If you install Form Builder 2, you should NOT install those other extensions:
-Universal Email
- Digital File Pro
- HTML Editor
The only exception to this would be installing HTML Editor v3. the HTML Editor version available in Form Builder is version 2. If you want to have version 3, then install the Form builder compatibility build first, them instal HTML editor v3.
A Sound Design
Thanks for clarifying that for me Jason.
you're welcome.
