Error in preset manager
Thread began 6/02/2011 6:19 am by info4753 | Last modified 8/10/2011 3:15 pm by Jason Byrnes | 1578 views | 7 replies |
info4753
Adding a new Design in the CSS Form Builder preset manager causes the following error:
TypeError: this.wadom.documentElement has no properties
Delete the Dreamweaver Cache file from the users configuration folder:
info4753
Adding a new Form gave me again a JavaScript error.
I'll try to delete the cache file ... :-|
add this info to the ticket I started earlier for other problems you are having and we will investigate this one with you too.
iain.sutherland290832
preset manager - same wadom issues
I am having the same issues with the preset manager - has there been any progress on a solution to missing wadom causing several subsequent messages and preventing the preview of the design. I deleted dat file and re-installed extension, but get the same issue.
what version of CSS FormBuilder do you have installed?
this issue should be corrected in the CSS Form Builder 2.0.1 - Support Release 2 version that is available in the download center.
if you have a previous version installed, you should uninstall it, then download and install the new version.
I am using CSS Form Builder 2.0.1 - Support Release 2 with dw5.5. I uninstalled v2.0 first. During the process I also appear to have lost some new designs I had created to speed up workflow. I can see some of the old xml form data for my bespoke forms in the old dw5 folders - can I copy and paste them into appropriate dw5.5 folders to recover them?
