Multiple Record Insert...
Thread began 6/01/2011 7:56 pm by Jim E D | Last modified 6/06/2011 4:00 pm by Jason Byrnes | 893 views | 3 replies |
Jim E D
Can you help me understand why the "Alternative Text" in the repeat selection is showing up?
Live...mkr_InsertMRC.php
Day 2 - okay really confused. This worked last night - came back today and retried live and on my WAMP testing server and the category table is not updating. I await some insight.
mkr_InsertMRC.zip
check for a blank record in the categories table causing the default text to be displayed.
as for the category table not updating, you have the initial insert behavior set to redirect after the first record gets inserted, this redirect happens before the categories can be inserted.
Jim E D
Multiple Record Insert...Notes...
I was using a Repeat Region to identify the categories. Once, I used the Repeat Selection tool instead of the repeat region I have been able to recreate the form MRI process.
Just a note in case someone else runs into this..
OK, glad to hear you found the problem.
