Select Year in Date Picker
Thread begun 6/01/2011 1:26 pm by Brad Lawryk | Last modified 6/02/2011 10:15 am by CraigR | 2815 views | 3 replies |
Brad Lawryk
Do you guys have any samples of Date Pickers built with this extension?
Can the picker have a drop down or something select a year? Example if someone is entering a birth date and was born in 1945 that is a lot of clicks to get to the year 1945 from 2011?
CraigRBeta Tester
the datepicker is highly configurable.
to add a year option and set the range from 1930 to 2010 you add the following lines to your code
$(function(){
$('#datepicker_1').datepicker({
dateFormat: 'dd/mm/yy',
showAnim: 'show',
onClose: closeDatePicker_datepicker_1,
changeYear: true,
yearRange: '1930:2011'
Here is an example, using the code above
datepicker.php
There is a lot of documentation here...
datepicker/
Dennis
Just what I needed
Craig,
Thanks for the tip & links.
I made a slight modification (yearRange: '1880:+01') so as not to have to change the end year every year.
Dennis
CraigRBeta Tester
Good idea.
Glad it was of help.
