Html editor icons layout messed up
Thread began 6/01/2011 9:46 am by info271221 | Last modified 6/02/2011 1:50 pm by Jason Byrnes | 1195 views | 3 replies |
info271221
Html editor icons layout messed up. I think I am missing a style sheet or ?? I removed my main style sheet and it did not resolve the issue and I don't believe I changed anything on my style sheet to make anything mess up. I did move the site from the public to the secure folder but I republished the webassist folders. Please see attached html editor view. The file manager view is basically the same. Thank You,
most likely the problem happened when you moved the file from the public to the secure folder. I would suspect that the links to the required files did not get updated when you moved the file.
I would suggest recreating the page, this time creating it in the secure folder to begin with, rather than moving the file after the fact.
info271221
I tried removing the html editor and adding it back in and that did not do the trick. The page was created by databassist so re-creating that is not an easy task and this is a live site the customer is using this page every day to update their website. Any idea if there are certain files or links that are broke? Thanks
