add to cart - jumps to op of page
Thread began 6/01/2011 3:45 am by this_is_me | Last modified 6/07/2011 3:01 am by this_is_me | 1118 views | 2 replies |
this_is_me
maybe a small issue but its annoying - after pressing the button to add a product to cart it always jumps to top because the action is:
<form name="eCart1_1_ATC_<?php echo $row_WADAwein["weinID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_WADAwein["weinID"]; ?>" ><strong><input type="text" name="eCart1_1_Quantity_Add" value="1" size="2" >&nbsp;&nbsp;<?php echo $row_WADAwein['gebName']; ?>&nbsp;(<?php echo $row_WADAwein['gebAnz']; ?> Flaschen) - &#8364;&nbsp;<?php echo number_format($row_WADAwein['Preiseinheit'],2,',','.'); ?></strong><div align="right"><input type="submit" class="eC_FormButton" value="In den Warenkorb legen" name="eCart1_1_ATC"></div></form>
If the list of products is long a client always has to scroll down to find the spot where he has been to add a product.
Is there a way to keep the page at the same spot after adding?
no, you should have the add to cart button set to redirect to the cart display page after the item is added to the cart.
this_is_me
Thank you, but how about this?
thank you for your suggestion, but this is not what the customer wants - he wants the client stay on the order page as long as possible. So, a quick and dirty workaround is, to add a named anchor:
<a name="poswine<?php echo $row_WADAwein["weinID"]; ?>"></a>
and the form action is expanded with a page link:
action="<?php echo $_SERVER["PHP_SELF"]; ?>#poswine<?php echo $row_WADAwein["weinID"]; ?>
So, after adding a product, the form action leads to the spot where the named anchor sits. I know its not terribly elegant but at least the client finds the last ordered item on top of the page. This is helpful if we have a very long list of products.
I hope this helps all those who have the same problem.
