Install errors in PowerStore 4 trying to use gallery
Thread began 5/31/2011 11:46 am by JOE352699 | Last modified 6/01/2011 1:33 pm by Jason Byrnes | 990 views | 3 replies |
JOE352699
After install PowerStore 4, i'm getting this error when trying to use gallery.
Warning: require_once(../Connections/powergallery.php) [function.require-once]: failed to open stream: No such file or directory in /homepages/34/d368894856/htdocs/galleries/global.php on line 4
Fatal error: require_once() [function.require]: Failed opening required '../Connections/powergallery.php' (include_path='.:/usr/lib/php5') in /homepages/34/d368894856/htdocs/galleries/global.php on line 4
see site at www.bbmcontainer.com
using 1&1 servers.
DarylBeta Tester
Looks like you need to upload the galleries directory
JOE352699
Generated by the install program and can load images into the gallery just cant call them.
Is there a setting some where that I can redirect the call from.
