SA2 - not tables shown in local database connection
Thread began 5/31/2011 2:47 am by info97301 | Last modified 6/01/2011 2:00 pm by Jason Byrnes | 631 views | 3 replies |
info97301
Hi
I have a local setup which works fine - have tested the connection and it works. (This is my last php site that still uses the old ADDT and I'm trying to convert it. I have removed all ADDT settings from the pages).
However, when I start the SA2 'Create Security Pages' wizard, I choose <new from blank>, then select my database connection from the drop-down list, then ...nothing!
No tables are displayed in any of the subsequent drop-down menus.
However, if I change the preset option to 'Simple Registration SP', then the tables appear in the dropdown, as do the userid and other fields. (But if I then switxh back to <new from blank> they disappear)
Cheers
Chris
I assume that your database has tables in it, and those tables have columns? if the database does not have any tables in it, there will be nothing to display in the list of available tables when you select the <New From Blank> option. The other options show the columns because they are presets that will create the table for you.
if you do have tables that are not displaying in the list, start by deleting the Dreamweaver Cache file from the users configuration folder:
then in your OS file browser, go to the root of your Dreamweaver site and delete the _mmServerScripts folder.
info97301
Hi Jason
Yes, the database and tables exist.
I have deleted the site cache and removed the folder you describe - but it hasn't made any difference.
I do wonder if the installation has caused a problem with Dreamweaver, as it now takes forever to start up!
Cheers
Chris
