Worldpay for PS4
Is there a guide to setup Worldpay in PS4. Ive read this
ps_change_pmtgateway_ecart.pdf
but its for the older version of powerstore.
No, we do not offer support for changing the gateway in Power Store 4.
Thanks for the reply.
I did purchased powerstore 4 based on your instructions on
"Changing PowerStore’s payment gateway with eCart"
Thinking that the payment gateways can be easlily changed via eCart. If you are not prepared to offer instructions maybe someone else can or you can point me to a thread that has..
thanks Lee
That PDF is under the Archived Documentation section and applies only to Power Store 3, In Power Store 4 it is not supported to change the payment gateway using eCart.
Can anyone else help me to add worldpay to powerstore 4.
Ive added the option and params in the admin area and also it directs to the worldpay page on checkout. but i know it then has to process the response.
Where does this happen?
thanks
Did you ever gat this sorted? I'm doing a PS4 integration for a client at the moment and will be amending PS to use Worldpay so I may be able to help.
