insert date
Thread began 5/26/2011 3:19 pm by mr hankey | Last modified 5/27/2011 9:49 am by Jason Byrnes | 708 views | 3 replies |
mr hankey
insert date
hi,
in my form where the users enter the date, they enter it in dd/mm/yyyy however it does not insert into the database as the database be default take it as yyyy-mm-dd.
how can i get it to insert into the database? can i change the database format or can it be done in data assist?
thanks
in the insert record behavior, when you bind the date column to the date form element, it will generate code like this:
<?php echo((isset($_POST["dateField"]))?$_POST["dateField"]:""?>
you will need to use the strtotime() and date() functions to convert the date format to thewhat is expected by the database:
<?php echo((isset($_POST["dateField"]))?date("Y-m-d h:m:s"strtotime($_POST["dateField"])):""?>
mr hankey
thanks so much jason that worked a treat.
thank you.
no worries
