How to 'Show a graphic tick, in a visited link'?
Thread began 5/26/2011 7:14 am by email405213 | Last modified 5/27/2011 6:15 am by email405213 | 3323 views | 3 replies |
MarkBeta Tester
Just wondered is it possible to show to a graphic 'tick' (jpg, gif etc) to appear just to the left or right of a visited menu item, and how would I acheive this?
Or has anyone already done this, or anyone having problems or solutions etc.
Many thanks!
Mark
neilo
That would depend on the menu you are using (assuming it is a CSSMenuWriter menu). Some already use background images for normal and hover states, so adding a tick image wouldn't work on those without a clear understanding of how the (usually three) bg images were styled.
It would be fairly straight forward to add a tick as a background image to the visited style of a menu item that did not already have a background image:
[element_name] a:visited {
/* your existing styles */
background-image: url(images/tick.png);
background-repeat: no-repeat;
background-position: right center;
That would display the image at the right. Your list menu would obviously need to be wide enough to accomodate it and clear the link text. You could add a padding-right:XXpx to the element the same width as the tick image if you wanted to make sure the link text didn't overlap the tick image.
This would need to be done after the CSSMenuWriter has done its job, otherwise you could lose the changes.
MarkBeta Tester
Hi neilo,
Thank you for replying, appreciate that.
Yes, done as you say, and also created a visited link in the Design tab in the cssmenu wizard, and still any image I do, either hard-coded to the url (http) or done via the site root (../ etc) - does not work or show the image - any image?
I'm using latest versions of chrome, ie9 and firefox 4. Whenever a menu item is clicked, it will show the original background grad (selected from the wizard) but will not show the background from the visited link (it will however show the text colour, or a coloured solid background when visited - just no images?
R, Mark
MarkBeta Tester
more info
hi
apparently, according to this link, there is no way now, to show a graphic image as a visited link because of some sort of privacy thing (excuse my ignorance, I'm not much at understanding programming code and such like):
privacy-related-changes-coming-to-css-vistited/
Anyone have any workarounds, I (and probabily other developers) will be most grateful.
There is a paragraph in the above article which says:
•If you’re using background images to style links and indicate if they are visited, that will no longer work.
It seems coloured backgrounds will work on visited links though?
R
