Security Assist 2
Excellent update!
Thanks a lot for your efforts! Finally there is a replacement for the ADDT security tool available.
I suggest that you also add a login history extension.
Excellent update!
I agree that this is a great update.
Regarding your login history extension - is Data Assist not capable of that? Simply Insert a login record into a table after authentication has either failed or succeeded (i.e. Use the Rules Manager to see if the authentication was successful, and write the results to the table).
Just a thought.
Cheers
Ian
Yes and I will also say that I think the new Security Assist 2 extension is great. It's very easy to use and is better organised than SA1. Like the new CSS3 button creation tools too.
Keep up the good work WA.
Two Ians from Stoke-On-Trent.... How intriguing!
I guess it really is a small world !!
Good idea, I'll check that ...
