Security Assist 2 Integrations
Thread began 5/24/2011 2:52 pm by tgrudzien | Last modified 5/25/2011 10:11 am by Jason Byrnes | 1368 views | 1 replies |
tgrudzien
I was wondering which extensions that security assist integrates with. Also I am using Framework Builder with SecurityAssist and use the pages as plugins. Has anything changed in the way this works?
Could you also explain the optimal way to turn SecurityAssist Pages into plugins then call them from Framework. There isn't any documentation on this type of integration and though it is working on my site I wish to review how someone at Web Assist would suggest doing it.
Thank You for your time!
Tim
security assist integrates the server validation of Form Toolkit, it includes a new validation type "Unique Database Value" which is used to check that the email.username entered on registration has not been registered already. It can be used for other columns as well though.
It includes the Insert record and Update record behaviors from Data Assist.
security assist pages can be used as dynamic plugins with framework builder. the key to using dynamic plugins, is the variable used to determine which plugin page to load.
I usually use the action query string variable, for example.
index.php?action=registration
index.php?action=login
you will need to modify the action of the forms to use the following code:
<?php echo htmlentities($_SERVER["PHP_SELF"]); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentities($_SERVER["QUERY_STRING"]):""?>
you will also need to edit the redirects for the various server behaviors to pass the appropriate query string variable to load the appropriate plugin.
