Data Assist Update Issue
Thread began 5/24/2011 12:54 am by johna1964 | Last modified 5/24/2011 2:52 pm by Jason Byrnes | 885 views | 3 replies |
johna1964
I just finished the wizard and began testing...all is good except the update records.
I am sent to a page with the following:
Table 'wa_ecommerce_db.undefined' doesn't exist...so I must enter the correct database information somewhere? I thought the database connection was configured correctly at the beginning of the data assist wizard...
Can you tell me what I need to do to correct this issue...I am working in a local testing environment...phpMyAdmin...
Thanks!
johna1964
double click on the update record server behavior and make sure all of the columns have the correct data type specified.
johna1964
Jason,
The columns had the correct data type specified, but it had an extra column for some reason, the "undefined" with a red exclamation mark next to it. I decided to reran the wizard again and do not have a problem now. It's working...kind of odd...have you ever had something similar happen like that?
Thanks again!
johna
No, I've not seen that before, glad to heart it is now working.
